[GRASS5] r.flow: strange compile error M_PI
Thu Jun 23 12:51:17 EDT 2005
Hamish wrote:
> > > > > > after an update of the Linux OS, I am no longer able to
> > > > > > compile r.flow:
> > > > > > aspect.c: In function `aspect_fly':
> > > > > > aspect.c:50: error: `M_PI' undeclared (first use in this function)
> > > I believe I have found the culprit.  M_PI is not defined when specifying
> > > the -ansi compiler option.
With GNU libc, it's conditionalised upon:
	#if defined __USE_BSD || defined __USE_XOPEN
Using -ansi alone breaks various other things. If you want to disable
gcc language extensions but allow various libc extensions, add
-D_GNU_SOURCE to the compilation switches. If you want X/Open
extensions but not GNU extensions, use -D_XOPEN_SOURCE=500.
There is a list of extension-enabling macros at the top of features.h.
Essentially, using -ansi without any other switches results in ANSI
headers (math.h, stdio.h etc) only declaring those functions defined
by the ANSI standard.
> There was talk of this on another maling list I follow a month or so back,
> some postings from the experts over there follow. (sorry for the long
> post, but it is interesting reading if you are into this sort of thing.)
> A question: do we want to be strict ANSI ISO C90 compliant or strict
> POSIX compliant? Is there any reason to be stricter than POSIX?
> i.e. gcc -ansi is good at keeping us honest, but does it go too far?
We don't want to require anything beyond ANSI C90 without good reason.
Given that defining M_PI etc is trivial, it doesn't make sense for
GRASS to refuse to compile on a platform which doesn't have them in
the system's headers.
