[GRASS5] v.in.ascii
Radim Blazek radim.blazek at gmail.com
Mon Jun 27 08:55:27 EDT 2005
Support structures are not released by default because it take long time
and it is much faster if it is done by system.
You have to call Vect_set_release_support() before
Vect_close() if you want to use valgrind.
Radim
On 6/24/05, Hamish <hamish_nospam at yahoo.com> wrote:
> Right, valgrind is done for 'v.in.ascii -zt'
> I used the first 250,000 points from the sample lidaratm2 dataset.
>   http://bambi.otago.ac.nz/hamish/grass/memleak/v.in.ascii/
> Three un-freed calls sum to 91% of the still reachable memory at program
> termination.  (roughly 300 bytes lost per vector point)
> RTreeNewNode (node.c:47)
> dig_alloc_line (struct_alloc.c:112)
> dig_alloc_node (struct_alloc.c:46)
> A test following children processes is running now, but I think the
> above three are the major culprits. Will add these results to the page
> later in the day. (but I'm running with -t so no DBF stuff)
> Hamish
