[GRASS5] [bug #3374] (grass) ps.map - error in margins or paper size handling
Request Tracker grass-bugs at intevation.de
Mon Jun 27 15:26:23 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3374
The example based on spearfish60.
Grass61 cvs 21.06.2005.
GRASS 6.1.cvs (spearfish60):~ > g.region rast=elevation.10m -ap
projection: 1 (UTM)
zone:       13
datum:      nad27
ellipsoid:  clark66
north:      4928000
south:      4914020
west:       590010
east:       609000
nsres:      10
ewres:      10
rows:       1398
cols:       1899
1 ps.map input=spear_ps.txt output=spear_ps.ps
where spear_ps.txt contains:
raster elevation.10m
paper a4
top 0.0
bottom 0.0
left 0.0
right 0.0
end
2 Open in gv with "Automatic" paper size enabled:
- on the right paper canvas stands out of the frame, which is thinner here
than the bottom and left frame,
- on the top the frame is only slightly visible (almost not visible at all).
3 Force A4 size in gv:
- right frame dissapears for good, only a one pixel-wide column of paper
canvas is visible.
Similar behaviour on other setups.
Maciek
--- Headers Follow ---
>From werchowyna at epf.pl  Mon Jun 27 21:26:23 2005
Return-Path: <werchowyna at epf.pl>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 6339F1005B0
	for <grass-bugs at lists.intevation.de>; Mon, 27 Jun 2005 21:26:23 +0200 (CEST)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 99D3E36E43
	for <grass-bugs at lists.intevation.de>; Mon, 27 Jun 2005 21:26:22 +0200 (CEST)
Received: from mail131.pi.net.pl (gips.pi.net.pl [195.116.221.99])
	by mail.intevation.de (Postfix) with SMTP id 606D136CE4
	for <grass-bugs at intevation.de>; Mon, 27 Jun 2005 21:26:19 +0200 (CEST)
Received: (qmail 2757 invoked from network); 27 Jun 2005 19:26:18 -0000
Received: from unknown (HELO eustahiush) (werchowyna at epf.pl@62.29.228.192)
  by 195.205.153.131 with SMTP; 27 Jun 2005 19:26:17 -0000
Message-ID: <010a01c57b4e$139f4e00$c0e41d3e at eustahiush>
To: <grass-bugs at intevation.de>
Subject: ps.map - error in margins or paper size handling
Date: Mon, 27 Jun 2005 21:25:10 +0200
MIME-Version: 1.0
Content-Type: text/plain;
	format=flowed;
	charset="iso-8859-2";
	reply-type=original
Content-Transfer-Encoding: 7bit
X-Priority: 3
X-MSMail-Priority: Normal
X-Mailer: Microsoft Outlook Express 6.00.2900.2180
X-MimeOLE: Produced By Microsoft MimeOLE V6.00.2900.2180
X-Antivirus: avast! (VPS 0524-1, 2005-06-14), Outbound message
X-Antivirus-Status: Clean
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
