[GRASS5] Re: Automatic gettextizations ; tables and g.html2man
    Markus Neteler
    neteler at itc.it
    Sat Mar  5 06:54:35 EST 2005
Hi Daniel,
(cc grass5)
On Fri, Mar 04, 2005 at 01:55:38AM -0500, Daniel Calvelo Aros wrote:
> Hi, Markus.
> I spent some time estimating the amount of work needed to _-mark all
> translatable strings. There is one case that can be fully automated: the
> G_(message|warning|fatal_error) functions. There is a mostly automatic case:
> description strings for options. There is a half automatic case: fprintf's.
> In the attached tarball there are two files. The important one is
> gettextize.cmds. It's a howto-commented script that tries to perform the
> automatic possible _-markings.
> 1. For G_*, it's straightforward: find all instances of
> G_(message|warning|fatal_error) calls, and enclose the constant strings
> therein with _(). I used a find-grep-perl filter to generate a context diff
> that is then patch'ed into the source tree. Only non-constant strings are left
> to be hand-marked, things like 'G_message(msg)'.
> 2. For option descriptions, the same principle applies, only care must be
> taken with multi-line strings, which I haven't found in the G_* calls.
> 3. For fprintf calls, it's trickier since they are mostly present in older
> code, which doesn't quite follow Radim's proposal of using stderr for anything
> informative and stdout for output proper. Also, there are several occurrences
> of fprintf being used for debug and exception signaling. In those cases, the
> output is meant to be read by the command's developper rather than the user.
> what I did was a find-grep filter, followed by hand editing of the resulting
> occurrences, followed by patch generation. The hand-edited intermediary file
> is 'fprintf_nongettexted', and corresponds to 6.0.0beta2. I'm not sure it's as
> useful as the other two conversions.
thanks for your work. I have attached for the list the
gettextize_auto.tgz script for further discussion (which hopefully happens).
> Finally, as I was happily perling, I remember having come across a message by
> yourself to grass5 list where you sought to have <table>s managed in
> g.html2man; I attach a patch that allows for *well-formed* <table> entries to
> be translated to tbl markup. (By well-formed I mean using <th></th> as actual
> headers, not boldface markers and closing <td> and <tr> correctly.)
Very nice, uploaded to CVS (please verify:
 cvs up tools
 cd man
 make
> I ran the automatic converter on beta2 sources, and I got some 1700 undefined
> entries in grassmods. Scary. I haven't run through it, but it is possible that
> several messages are slight variations of each other and should be merged
> accordingly. That should go along the *huge* work of going module by module
> checking proper usage of output.
In fact, we have to somewhat cleanup the messages to avoid that
it becomes an endless story. This is time consuming, but consider
the time needed to replicate translations for n languages...
> I hope this is helpful.
Definitely! Please consider to subscribe to grass5 to participate
in the discussion (changing to digest mode/mime you can keep the number
of mails smaller if needed).
Thanks for your input
 Markus
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050305/28d88dd7/gettextize_auto.tgz
