[GRASS5] Re: Automatic gettextizations ; tables and g.html2man
    Radim Blazek
    blazek at itc.it
    Mon Mar  7 03:53:06 EST 2005
G_debug (int level, char *msg) should be changed to macro with suggested
line/row additions and the macro should also do nothing (don't call any
function) if GRASS is compiled without debug, that should also speed it up.
Radim
Hamish wrote:
>>Mmmmh... Would it make sense to have a G_debug macro/function (in
>>gis.h? not sure...) to help in that? I was thinking of something like
>>providing
> Radim has already provided this ;)
> lib/gis/debug.c
>  * G_debug (int level, char *msg)
>  * Print debugging message if environment variable GRASS_DEBUG_LEVEL
>  * is set to level equal or greater
>  * Levels: (recommended levels)
>  * 1 - message is printed once or few times per module
>  * 3 - each row (raster) or line (vector)
>  * 5 - each cell (raster) or point (vector)
> example:
> int cat;
> G_debug(3, "cat=%d", cat);
> GRASS> g.gisenv set="DEBUG=3"
> GRASS> g.module
> D3/3: cat=123
> GRASS>
> This is new for 5.7/6.0 though, so while the new vector modules make
> good use of it the old raster and display modules inherited from 5.0 and
> earlier use lots of "#ifdef DEBUG" variations. Pre-processing should cut
> all these out, so for your translation focusing efforts, perhaps run the
> scripts on the cleaned version of the source code? (man gcc)
> On the positive side, a lot of those error messages are there in case
> there is a bug in the program, hopefully they will never be shown. Thus
> they are very low priority for selective translating.
> Fixing things to be translation friendly in all modules is a huge amount
> of work. I think a good way to start is to define some best practices
> and add them into the SUBMITTING file. Then at least whenever a module
> gets a re-write or a new module appears it will be easy.
> Also new for 5.7/6.0 is G_define_standard_option(). Updating modules to
> use this instead of a custom version every time would also make your
> efforts a bit simpler.
>>Another annoyance in translations is several lines
>>of fprintfs instead of one multiline string. That's quite
>>uncomfortable when editing po-files. I'll look into it, it must be
>>detectable automatically.
> Does this work for all compilers?
> search:
> grep -A1 printf | sed | uniq --repeated
> or something like that?
> Hamish
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
