[GRASS5] options order in GUI
Radim Blazek blazek at itc.it
Thu Mar 10 04:24:35 EST 2005
Maciek Sieczka wrote:
> regarding bug http://intevation.de/rt/webrt?serial_num=3017
>> I encounter a segfault with one particular dataset with the following
>> options:
>> GRASS 6.0.cvs:~ > v.clean input=i output=j type=area err=j_err
>> tool=break,rmdupl,rmdac,bpol,rmarea
> Radim Blazek wrote:
>>> I fixed that, however:
>>> 1) bpol should be used as first cleaning tool, it does the same as
>>> break, but it is faster on clean (identical boundaries) polygons
> I can't change the order of cleaning tools using v.clean in GUI. The order
> is hardcoded. Could that be fixed Michael? Options order issue also refers
> to v.type in GUI http://intevation.de/rt/webrt?serial_num=2969.
>>> 2) bpol works only with type=boundary, the same break,rmdupl etc.
> Radim, do you mean that "rmdupl" and "break" should not be used with
> type=line?
> Maciek
> P.S.
> This is the 3rd time I'm sending this to the list in last 2 days. I've been
> also forwarding to Michael and Radim but nobody answered thus I assume
> nobody got my email by now. Maybe now, sending only to the list, will
> deliver my message somewhere.
I think that I answered the 2)
http://grass.itc.it/pipermail/grass5/2005-March/017673.html
The order could be changed in C code, but it is not systematic solutin,
because tools can also repeat and there is no correct order for all
situations.
Radim
