[GRASS5] more cats in one layer and where condition
Radim Blazek blazek at itc.it
Thu May 5 04:48:01 EDT 2005
Martin Landa wrote:
> Hi,
>>>the problem which I described in last e-mail (d.vect disp=cat|attr
>>>where=) is more complex (as I have found out using ps.map)...
>>does v.extract work or does it have the same problem?
> it seems that v.extract works correctly...
> btw, I am trying to add multiple layer support to this module.
> 	v.extract ... [layer=value[,value,...]] ...
> It is almost done.
How should it work? Currently the layer option is used together with
(list or where) and type. How do you want to use more layers?
Radim
> Martin
> Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
> CTU Prague, Faculty of Civil Engineering, Czech Republic
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
