[GRASS5] New thematic mapper for GRASS 6
Jachym Cepicky jachym.cepicky at centrum.cz
Thu May 12 11:00:53 EDT 2005
hallo
On Thu, May 12, 2005 at 04:21:51PM +0200, Moritz Lennert wrote:
> Great ! But watch out: I think the patch is not against the latest version of
> the code which fixes the bug of a possible missing value in the first
> category...
sorry,
now I patched the file against patched d.vect.thematic from Martin Landa
> > d.vect.thematic could be renamed to v.thematic... or even v.colors :-) ?
> I think d.vect.thematic is better as the module is clearly a display module.
> Moritz
well, now it is display & update module
Jáchym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
109a110,116
> #%flag
> #% key: u
> #% description: Update color values to the table
> #%end
> # setting environment, so that awk works properly in all languages
> export LC_NUMERIC=C
140a148,161
> # update color values to the table?
> if [ "$GIS_FLAG_u -eq 1" ] ; then
>     # which is the database table?
>     table=`v.db.connect -g $GIS_OPT_map |grep $GIS_OPT_layer | awk '{print $2}'`
>     # test, if the column GRASSRGB is in the table
>     if [ "`db.columns $table | grep -i grassrgb`" == "" ] ; then
>         echo "Creating column 'grassrgb' in table '$table'"
>         "ALTER TABLE $table ADD COLUMN grassrgb varchar(11)"|db.execute
>     fi
> fi
143c164,167
< v.univar.sh -e table=$GIS_OPT_map column=$GIS_OPT_column > TMP1
> dblink=`v.db.connect $GIS_OPT_map -g | grep -w $GIS_OPT_layer`
> driver=`echo $dblink | awk '{print $5}'`
> database=`echo $dblink | awk '{print $4}'`
> v.univar.sh -e table=$GIS_OPT_map column=$GIS_OPT_column drv=$driver db=$database > TMP1
230a255,262
>             # update color to database?
>             sqlwhere="$GIS_OPT_column>$rangemin and $GIS_OPT_column<=$rangemax"
>             if [ $GIS_FLAG_u -eq 1 ] ; then
>                 echo "UPDATE $table SET GRASSRGB = '$themecolor' WHERE $sqlwhere"\
>            | db.execute
>             fi
232c264
<                 where="$GIS_OPT_column>$rangemin and $GIS_OPT_column<=$rangemax" \
>                 where="$sqlwhere" \
263a296,303
>            | db.execute
>         fi
265c305
>             where="$sqlwhere" \
284a325,331
>            | db.execute
>         fi
286c333
>             where="$sqlwhere" \
301a349,355
>            | db.execute
>         fi
303c357
>             where="$sqlwhere" \
322a377,384
>            | db.execute
>         fi
324c386
>             where="$sqlwhere" \
343a406,412
>            | db.execute
>         fi
345c414
>             where="$sqlwhere" \
360a430,436
>            | db.execute
>         fi
362c438
>             where="$sqlwhere" \
382a459,465
>            | db.execute
>         fi
384c467
>             where="$sqlwhere" \
399a483,489
>            | db.execute
>         fi
401c491
>             where="$sqlwhere" \
416a507,513
>            | db.execute
>         fi
418c515
>             where="$sqlwhere" \
433a531,537
>            | db.execute
>         fi
435c539
>             where="$sqlwhere" \
457a562,568
>            | db.execute
>         fi
459c570
>                 where="$sqlwhere" \
484a596,602
>            | db.execute
>         fi
486c604
>             where="$sqlwhere" \
497a616,622
>            | db.execute
>         fi
499c624
>             where="$sqlwhere" \
506a632,638
>            | db.execute
>         fi
508c640
>             where="$sqlwhere" \
519a652,658
>            | db.execute
>         fi
521c660
>             where="$sqlwhere" \
532a672,678
>            | db.execute
>         fi
534c680
>             where="$sqlwhere" \
541a688,694
>            | db.execute
>         fi
543c696
>             where="$sqlwhere" \
559a713,719
>            | db.execute
>         fi
561c721
>             where="$sqlwhere" \
568a729,735
>            | db.execute
>         fi
570c737
>             where="$sqlwhere" \
577a745,751
>            | db.execute
>         fi
579c753
>             where="$sqlwhere" \
586a761,767
>            | db.execute
>         fi
588c769
>             where="$sqlwhere" \
