[GRASS5] Re: grass5 digest, Vol 1 #1667 - 4 msgs
Michael Barton michael.barton at asu.edu
Sat May 14 12:47:25 EDT 2005
On 5/14/05 4:01 AM, "grass5-request at grass.itc.it"
<grass5-request at grass.itc.it> wrote:
> Why not an icon in GIS Manager?
> Select the vector map in the list and press the thematic icon. It
> have to extract the vector name automatically.
OK. I¹m working on this. I¹ve got the basic interface done and now need to
add in the thematic code. The main issue I see at this point is how to
create even a text legend. I thought I might be able to do it using d.graph,
but this only shows the standard GRASS colors AFAICT (.e.g., red, green,
blue,...). I need to learn how to send tcltk output to a new and different
window. I can get it into a file, but users will want to see the results
without opening the file.
> Other future option:
> * thematic mapping for TEXT values. Unique values
This depends first on whether the GRASS subset of SQL will produce a unique
value query. This is the easiest way to go, but I don¹t remember seeing the
Œunique¹ keyword in the SQL list. There are other ways to do this (the way I
did v.lda, for example) but they aren¹t as straightforward.
> Great work Michael
Thanks very much.
Michael
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20050514/0f7b8012/attachment.html
