[GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
Request Tracker grass-bugs at intevation.de
Mon May 16 10:32:14 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3246
Subject: d.vect.thematic fails when the map is in another mapset
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: grass61_cvs_2005_05_16
Michael
The map 'gminy_zw' is in mapset 'robot'. When displayed with d.vect.thematic from within the 'robot' mapset all is OK. But when from another mapset d.vect.thematic fails:
d.vect.thematic 'themetype=graduated colors' themecalc=interval map=gminy_zw at robot column=KK layer=1 type=area icon=basic/circle size=5 maxsize=20 nint=4 colorscheme=red-blue singlecolor=red
dbmi: Protocol error
awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
Thematic map legend for column KK of map gminy_zw at robot
Value range:  -
Mapped by 4 intervals of
Color(R:G:B)	Value
250:0:0		>0 - 0
BTW - can the colortable be stored in GRASSRGB column? I guess you where discussing this on the list but I can't find the option in d.vect.thematic.
Many thanks for this module, I'm sure it will be usefull for many of us.
Maciek
-------------------------------------------- Managed by Request Tracker
