[GRASS5] d.nviz functional?
Markus Neteler neteler at itc.it
Tue May 17 12:35:37 EDT 2005
I currently try to generate a flight path for NVIZ with
d.nviz. While it works for Bob, it doesn't for me.
Of course latest GRASS 6.1-CVS (maybe Bob does not use
the current CVS version).
I would like to ask if a list member could try in Spearfish:
 g.region rast=elevation.dem
 d.nviz -ick inp=elevation.dem out=flight dist=500 ht=30 frames=200
 # then digitize a nice path
 nviz nviz el=elevation.dem  script=flight
According to Bob NVIZ should start, load the DEM, and start
to render the flight. It should output a new script flight.kanimator
as well.
In my version nothing like this happens, it just loads the DEM.
To narrow down the problem we need volunteers to test the
current NVIZ...
Thanks
 Markus
