[GRASS5] d.nviz functional?
Bob Covill bcovill at tekmap.ns.ca
Tue May 17 15:43:35 EDT 2005
Hi Markus,
I have dug into the scripting problem and found a potential problem.
Each command in the script is executed by the procedure SendScriptLine.
This procedure can be found in script_support.tcl.
This procedure uses the TK "send" command which is probably the source
of the problems.
To identify if the send command is failing change the following line
from SendScriptLine
catch {send $ProcessName "$line"} rval
to
This will allow any errors from "send" to be output to stderr.
With my CygWin installation I recieved the following error ...
X server insecure (must use xauth-style authorization)
Let me know if you get a similar error. I am not sure of a work-around
for this yet. Presumably any any system not using xauth will have the
same problem?
Bob
