[GRASS5] Libgrass_gis on Mingw - open.c patch
Javier A. Yebrin javier.yebrin at ing.unitn.it
Thu May 19 12:53:24 EDT 2005
I'll send the build errors as soon I get my work organized. I've started
with some real testing and recompilation. The current module undergoing this
test is r.average, which is presenting some problems because of system calls
to r.stats and r.recode.
I'm thinking of writing the r.stats/recode modules as functions inside
r.average. Do you think this is feasable?
Javier
> -----Original Message-----
> From: Glynn Clements [mailto:glynn at gclements.plus.com]
> Sent: Tuesday, May 17, 2005 6:01 PM
> To: Javier A. Yebrin
> Cc: 'Hamish'; grass5 at grass.itc.it
> Subject: RE: [GRASS5] Libgrass_gis on Mingw - open.c patch
> Javier A. Yebrin wrote:
> > > how about a list of what doesn't build?
> > Something like:
> > r.digit
> > r.out.ppm3
> > r.out.tiff
> > r.random
> > r.region
> > r.resamp.rst
> > r.surf.fractal
> > r.surf.gauss
> > r.surf.idw2
> > r.surf.random
> > r.terraflow
> > r.timestamp
> > r.to.vect
> > Some of them will not work because they need a GUI
> (r.digit). Others
> > maybe because of wrong configure flags (r.out.***).
> Can you provide the actual build errors for the above modules?
> Glynn Clements <glynn at gclements.plus.com>
