[GRASS5] [bug #3271] (grass) r.out.gdal should use gdalwarp instead of gdal_translate
Request Tracker grass-bugs at intevation.de
Mon May 23 09:29:18 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3271
Subject: r.out.gdal should use gdalwarp instead of gdal_translate
Platform: GNU/Linux/i386
grass obtained from: Other (CDROM etc)
grass binary for platform: Downloaded precompiled Binaries
r.out.gdal script should use gdalwarp instead of gdal_translate to offer the same expected feature than other r.out.* functions. The output raster should have the extent and resolution of the current region. A specific flag could be add to activate or desactivate this feature.
-------------------------------------------- Managed by Request Tracker
