[GRASS5] db_append_string
Radim Blazek blazek at itc.it
Mon May 23 10:10:51 EDT 2005
Jachym Cepicky wrote:
> Hallo,
> does db_append_string() support "ORDER BY" condition for SQL query? I tryed it
> but nothing has changed in the order of result.
> Jachym
The db_append_string() is only used to create query string. Important is
if 'order by' is supported by driver. dbf driver should support 'order
by'. Try db.select.
Radim
