[GRASS5] [bug #3272] (grass) Region windowing for vectors
Request Tracker grass-bugs at intevation.de
Mon May 23 13:07:46 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3272
Subject: Region windowing for vectors
Platform: Solaris2.X/Sparc
grass obtained from: CVS
grass binary for platform: Compiled from Sources
I would like to be able to output vectors windowed to the current region.  The current best way to do this is through either v.select or v.overlay, but neither of these quite does the trick when it comes to 3D vectors.
Certain functions, like v.delaunay, have a -r switch to window the vector to the current region, and it would be nice if v.out.ascii had the same switch.
Thanks,
Gilead Wurman
ASU Active Tectonics
-------------------------------------------- Managed by Request Tracker
