[GRASS5] Updated d.vect.thematic
Moritz Lennert mlennert at club.worldonline.be
Mon May 23 18:38:08 EDT 2005
On Mon, May 23, 2005 20:40, Michael Barton said:
> Daniel
> I used your awk code, as it is simpler than mine. I've attached a copy here.
> I'm baffled as to why Moritz is getting a bad color value.
> Moritz,
> Try the new code here.
The new code works !
> If it doesn't work, please take a look at the ascii
> group file that d.vec.thematic is creating. Where are the color values off?
> Do you have a non-GNU version of AWK?
I had attached the group file to my last mail.
I am using mawk which is the default awk version on Debian. Maybe this was the
problem.
Thanks once again.
Moritz
