[GRASS5] [bug #3277] (grass) d.vect.thematic fails with DOUBLE
Jachym Cepicky jachym.cepicky at centrum.cz
Wed May 25 09:10:07 EDT 2005
hi,
this should be solved by
    export LC_NUMERIC=C
at line 167 of d.vect.thematic ...
is you d.vect.thematic not a bit older?
Jáchym
On Wed, May 25, 2005 at 11:47:05AM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3277
> Subject: d.vect.thematic fails with DOUBLE
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs_25_05_05
> d.vect.thematic works fine with INTEGER but fails with DOUBLE as follows:
> d.vect.thematic map=gminy_zw_2003_prc_dem 'themetype=graduated colors' themecalc=interval column=PROD layer=1 type=area icon=basic/circle size=5 maxsize=20 nint=4 colorscheme=blue-red singlecolor=250:0:0 startcolor=250:0:0 endcolor=0:0:250 monitor=x1
> awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
> Thematic map legend for column PROD of map gminy_zw_2003_prc_dem
> Value range:  -
> Mapped by 4 intervals of
> Color(R:G:B)	Value
> 0:0:250		. -
> DBMI-DBF driver error:
> SQL parser error in statement:
> SELECT cat FROM gminy_zw_2003_prc_dem WHERE PROD >=  and PROD<=
> Error in db_open_select_cursor()
> 62:0:188		. -
> SELECT cat FROM gminy_zw_2003_prc_dem WHERE PROD >  and PROD<=
> 124:0:126		. -
> 186:0:64		. -
> the vector file info:
> GRASS 6.1.cvs (caves_utm33):~ > v.info gminy_zw_2003_prc_dem
>  | Layer:    gminy_zw_2003_prc_dem          Organization:                     |
>  | Mapset:   admin                          Source Date:                      |
>  | Location: caves_utm33                    Name of creator:                  |
>  | Database: /home/grassdata                                                  |
>  | Title:        |
>  | Map Scale:  1:1                                                            |
>  | Map format: native                                                         |
>  |   Type of Map:  Vector (level: 2)                                          |
>  |   Number of points:       0               Number of areas:      23         |
>  |   Number of lines:        0               Number of islands:    5          |
>  |   Number of boundaries:   90              Number of faces:      0          |
>  |   Number of centroids:    23              Number of kernels:    0          |
>  |   Map is 3D:              0                                                |
>  |   Number of dblinks:      1                                                |
>  |   Projection: Universe Transverse Mercator (zone 33)                       |
>  |            N: 5739296.326    S: 5660045.543                                |
>  |            E: 633165.320     W: 564573.435                                 |
>  |            B: 0.000         T: 0.000                                       |
>  |   Digitize threshold: 0.00000                                              |
>  |   Comments:        |
> datbase info:
> db.describe table=gminy_zw_2003_prc_dem driver=dbf database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> table:gminy_zw_2003_prc_dem
> description:
> insert:yes
> delete:yes
> ncols:14
> column:CAT
> description:
> type:INTEGER
> len:11
> scale:0
> precision:10
> default:0
> nullok:yes
> select:yes
> update:yes
> column:NAZWA
> description:
> type:CHARACTER
> len:15
> scale:0
> precision:0
> default:
> nullok:yes
> select:yes
> update:yes
> column:PRZYR_PRC
> description:
> type:DOUBLE PRECISION
> len:5
> scale:2
> precision:3
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PRZEDPR
> description:
> len:8
> scale:2
> precision:6
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PROD
> description:
> len:8
> scale:2
> precision:6
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:POPROD
> description:
> len:7
> scale:2
> precision:5
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PRAC
> description:
> len:8
> scale:2
> precision:6
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PRAC_ROL
> description:
> len:6
> scale:2
> precision:4
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:BEZR_REJ
> description:
> len:7
> scale:2
> precision:5
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:ZATR
> description:
> len:5
> scale:2
> precision:3
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:NIEZATR
> description:
> len:5
> scale:2
> precision:3
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:GESTOSC
> description:
> len:7
> scale:2
> precision:5
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:WIES_KM2
> description:
> len:4
> scale:2
> precision:2
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:grassrgb
> description:
> type:CHARACTER
> len:11
> scale:0
> precision:0
> default:
> nullok:yes
> select:yes
> update:yes
> Maciek
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
