[GRASS5] viewing map attribute table
Markus Neteler neteler at itc.it
Wed May 25 09:13:22 EDT 2005
On Wed, May 25, 2005 at 03:00:49PM +0200, Moritz Lennert wrote:
> Except for the the fact that in one you chose a map and in the other a table,
> what is the difference between v.db.select and db.select ? (or is v.db.select
> just a sort of frontend to db.select ?)
db.select can access tables which are not vector maps (right?).
v.db.select is using the dblink definition of the map (right?).
Markus
