[GRASS5] Readline completion for grass
Daniel Calvelo Aros dcalvelo at minag.gob.pe
Thu May 26 22:43:02 EDT 2005
Sent: Fri, 27 May 2005 09:54:12 +1200
> Were you aware of the existing implementation?
No.
> look for "GRASS shell extension" at
>   http://grass.ibiblio.org/download/addons.php
> note the link is 404 not-found, so not much use to anyone. Maybe someone
> has an old copy though? This will surely be pre-GRASS 6 though so yours
> will be more up to date, but maybe it could help you.
Certainly it could.
Radim, you seem to have got circa 2002; is it still around? It didn't made it
to the source distribution, and Alexandre Sorokine (the original author) is
out of the web currently, it seems.
> Once you are happy with it, it can be added to the Add-Ons page in
> the wiki.  http://grass.gdf-hannover.de/twiki/bin/view/GRASS
Ok.
