[GRASS5] Grass 6.0cvs 21/05/2005 on Solaris Sparc
Ade Fewings ade at informatics.bangor.ac.uk
Sun May 29 12:42:26 EDT 2005
Glynn Clements wrote:
>Ade Fewings wrote:
>>>>A number of occurrences of not being able to find install-sh - typically
>>>>not enough or too many "../" - in builds in sub-directories of the grass
>>>>source.  However, I can fix these myself for my purposes - should they
>>>>be fed back here for info?
>>>What is INSTALL set to in include/Make/Platform.make?
>>INSTALL = "../.././install-sh -c"
>>Quick change fixes that one.
>>Didn't realise I should be changing that, sorry.
>I would have expected configure to set it correctly itself.
>Does it help if you specify the full path to configure, e.g.:
>	/usr/src/grass/configure ...
Indeed it does.  Strange.
Thanks
Ade
___________________________________________________
Ade Fewings MEng
School of Informatics, University of Wales, Bangor,
Dean Street, Bangor, Gwynedd. LL57 1UT. UK.
ade at informatics.bangor.ac.uk  www.informatics.bangor.ac.uk/~ade
Tel: +44 (0)1248 382736       Fax: +44 (0)1248 361429
