[GRASS5] r.out.gdal
Markus Neteler neteler at itc.it
Mon May 30 06:47:36 EDT 2005
On Fri, May 27, 2005 at 07:07:06PM +1200, Hamish wrote:
> r.out.gdal - broken with quoting problem.
>  (help?)
Is it possible that this problem was introduced when
making 'Krovak' et al. functional? For a while r.out.gdal
worked quite well.
BTW: I have patched the GRASS/GDAL plugin to report
the projection:
 http://bugzilla.remotesensing.org/show_bug.cgi?id=822
Frank didn't apply it yet, please test it and comment into
the bug report if things do[n't] work. This patch could
simplify r.out.gdal.
Markus
