[GRASS5] [bug #3277] (grass) d.vect.thematic fails with DOUBLE
Maciek Sieczka via RT grass-bugs at intevation.de
Mon May 30 14:42:38 EDT 2005
In Grass CVS 30.05.2005 d.vect.thematic still doesn't accept the DOUBLE data
but the error information is different:
d.vect.thematic map=gminy_zw_2003_prc_dem at admin type=centroid column=PROD
'themetype=graduated points' themecalc=interval layer=1 icon=basic/circle
size=5 maxsize=20 nint=4 colorscheme=blue-red singlecolor=0:250:0
startcolor=250:0:0 endcolor=0:0:250 monitor=x2 -l
ERROR: Column <PROD> is of type <double precision
double precision> which is not numeric.
Double precision is not numeric? (I'm only a simple user.)
Maciek
-------------------------------------------- Managed by Request Tracker
