[GRASS5] status of Tcl/Tk Aqua support on Mac OS X
William Kyngesburye woklist at kyngchaos.com
Fri Nov 4 10:29:15 EST 2005
As I understand it, in GRASS 6 (or 6.1 CVS at least), the most of the
Tcl/Tk interface has been rewritten so that it now runs in Mac OS X's
Tcl/Tk Aqua.  The part that still needs a UNIX build of Tcl/Tk is
NVIZ, and I think that has something to do some X11 program it uses
to get window info?  Is there any C code in NVIZ that needs the UNIX
Tcl/Tk?
Does this sound right?  Is 6.0.1 in line with 6.1 CVS?
What are the bits in NVIZ that need the UNIX Tcl/Tk?  If an
alternative could be found that works with Tcl/Tk Aqua, is it as
simple as changing some command references in the Tcl code?
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
