[GRASS5] New CSS based doc style for GRASS usage examples
Daniel Calvelo Aros dcalvelo at minag.gob.pe
Fri Nov 4 12:14:22 EST 2005
That's a great move. Do you think it makes sense to use another <div> for output?
Someting else: since this needs to be done for every description.html, it
might be good to revise the examples and make them all work with spearfish.
What do we gain? It's a very good starting point for building a (minimal) set
of regression tests. I'm positive that is something to do for 7.0.
I'm revising g.html2man to take care of line breaks within PRE. Should land on
CVS today.
Daniel.
-- Daniel Calvelo Aros
---------- Original Message -----------
To: grass developers list <grass5 at grass.itc.it>
Sent: Fri, 4 Nov 2005 17:21:41 +0100
Subject: [GRASS5] New CSS based doc style for GRASS usage examples
> Hi all,
> - documentation cosmetics -
> I have extended:
>  lib/gis/parser.c
>  include/Make/Html.make (separated from Rules.html)
>  tools/build_html_index.sh
> to generate an additional HTML header line to include a simple
> CSS style file. Basically the examples can be coded now
> like this in the 'description.html' files:
> <div class="code"><pre>
> v.to.db -p roads option=length type=line units=k
> </pre></div>
> Such an example appears indented with type write font in a grey box
> which makes it easier to distinguish in the text flow.
> And: Section titles are green colored now (such as the GRASS Web
> site).
> Example:
>  vector/v.to.db/description.html
> TODO 1:
> Now all the tons of examples should be homogenized and changed to
> above style.
> TODO 2: Fix tools/g.html2man/g.html2man to accept multiple lines
> in above environment (two or more lines of example in a single
> </pre></div>
> At time the line break is eaten and not preserved (hi Daniel, maybe
> you could help?). Maybe these examples could be indented a bit in the
> MAN pages?
> By tomorrow morning Italian time the updated man pages will be online.
> Markus
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
------- End of Original Message -------
