[GRASS5] v.to.db 2 new features compactness and perimeter
Wolf Bergenheim wolf+grass at bergenheim.net
Fri Nov 11 10:26:48 EST 2005
Wolf Bergenheim wrote:
> Radim Blazek wrote:
>> On 11/10/05, Wolf Bergenheim <wolf at bergenheim.net> wrote:
>>> Heh. defenately not... I use Vect_line_length() to calculate the length.
>>> perhaps the the fix should go in here? perhaps an additional parameter
>>> or a new fun Vect_line_length_meters(). I guess that the area is ok? or
>>> does it have a unit of square degrees? (;
>> There is Vect_line_geodesic_length but it should only be used with -g
>> flag.
> How about calculating the distance normally (the circumference, and then
> converting the angular distance to metric, by using:
> distance in meters = angle * pi * radius (which is what? 6365 km? Is
> there any way of getting the radius of the projection?)
Umm I meant to write:
length = (angle_length/360)*2*M_PI*radius;
> How can I deterimin if the projection is LL?
> --W
<:3 )---- Wolf Bergenheim ----( 8:>
