[GRASS5] debian control
Moritz Lennert mlennert at club.worldonline.be
Mon Oct 3 03:17:22 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Paolo,
Paolo Cavallini wrote:
> Hi all.
> After some experimenting, I found that the procedure to build a debian package
> from grass cvs is quite simple:
> - update from cvs the usual way
> - su
> dpkg-buildpackage
You can also use 'fakeroot dpkg-buildpackage'.
> The only problems I find are:
> - during cvs update some files are conflicting (as a result of previous
> compilations); it seems necessary to delete them for a successful compilation
Are you sure that the "conflicts" are a problem ? I just run a cvs
update on the repository and there does not seem to be a problem.
The only "conflicts" I see are specific debian files which are
handled by dpkg-buildpackage, not any of the GRASS source.
If you want to clean up your source tree before an update, you can
run 'debian/rules clean' which should do a clean including
unpatching debian patches. Then the conflicts should disappear...
> - I get the error
> reverting patch htmlgen-fakeroot from ./ ... failed.
>  make: *** [unpatch] Error 1
> This disappears if I delete the debian/ directory and rerun the process.
> Hope this helps smoothing things further (they're now just little annoyances,
> but it can take a while to sort them out the first time).
Sorry I couldn't give you above hints earlier, just stumbled upon
them myself.
Best,
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDQNsCrIrMbm76jD8RAmu8AJ95I7y0lB5JdLifV4ZOV5TPhMMBngCfW2zJ
N++JkLYzjLoDeLyTycEpfO0=
=kgX1
-----END PGP SIGNATURE-----
