[GRASS5] [bug #3741] (grass) r.cost WARNING: segment_pagein: No such file or directory
Request Tracker grass-bugs at intevation.de
Fri Oct 14 09:34:43 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3741
Subject: r.cost WARNING: segment_pagein: No such file or directory
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: CVS
the following problem appears when using r.cost:
r.cost in=allarea.one out=distance2water start_rast=streams percent_memory=100
Peak cost value: 64.485281
Interestingly, the result map is generated.
But the message is confusing.
Thanks
 Daniela
-------------------------------------------- Managed by Request Tracker
