[GRASS5] d.vect -a|c for all types ver2
Martin Landa landa.martin at gmail.com
Tue Oct 18 14:36:02 EDT 2005
Hi Markus,
2005/10/18, Markus Neteler <neteler at itc.it>:
> I tried, works well for areas and lines. But should it do also for points?
> I can submit as is and then (if time permits) you may get it
> working for points as well?
you are right, there is a bug, I have tested it only with
icon=basic/box and it worked.
I hope it is better now. Please, see png's at
http://k153-85.fsv.cvut.cz/~martin/.../d.vect-ac/
Any comments?
Best regards,
Martin
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051018/cd02d01c/d_vect_rgb_column-2005-10-18.diff.gz
