[GRASS5] Re: [bug #3709] (grass) d.m - commands output pollutes the Grass terminal
Fri Oct 21 09:54:05 EDT 2005
Glynn Clements wrote:
> > If you think it is better then to reopen this bug number for a different
> > issue, I guess that is your call. It just seemed to me that we solved the
> > first issue. Now that it's solved, another issue has become apparent. This
> > is often the case. I just want to make sure that the appropriate people take
> > a look at this. It's not d.m per se, but any commands (or possibly d.rast).
> > You'd get the same result if you did this from the command line.
> Yes, but if the commands are invoked by d.m, d.m should arguably be
> redirecting stdout and stderr to its internal log window.
To elaborate, the issue appears to be that run_panel is redirecting
the program's stdout/stderr to d.m's stdout/stderr rather than
consuming them itself or discarding them.
proc run_panel {cmd} {
	global outtext
	eval exec -- $cmd >@ stdout 2>@ stderr
	set str $cmd
	$outtext insert end "$cmd\n"
	$outtext yview end
	update idletasks
The same issue appears to apply to the run procedure.
Both should ideally be behaving like run_cmd from gui.tcl, i.e. using
open rather than exec, and using prnout (or an equivalent) to consume
the output.
Alternatively, a quick fix would be to redirect to /dev/null instead
of stdout/stderr.
