[GRASS5] [bug #3779] (grass) d.m: window height control between layers list and layer properties needed
Michael Barton michael.barton at asu.edu
Sat Oct 29 13:47:52 EDT 2005
If anyone knows how to implement a set of vertically-oriented paned windows
(monitor buttons and layer tree), followed by a pair of
horizontally-oriented paned windows (options panel and output window) with a
movable sash between them please implement it--or tell me and I will
implement it.
As far as I can see, you have to create paned windows as either vertical or
horizontal. That means that you have to create two different paned windows
if you want to switch from vertical to horizontal.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Fri, 28 Oct 2005 16:11:59 +0200 (CEST)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] [bug #3779] (grass) d.m: window height control between
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3779
> Subject: d.m: window height control between layers list and layer properties
> needed
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs 26.10.2005
> I miss the ability to control the height of layers list window and layer
> properties window in d.m. I find uncomfortable to control their height by
> dragging the d.m commands window, which is the only way for now.
> Otherwords, see:
> http://www.biol.uni.wroc.pl/sieczka/udostepnione/grass/dm/d.m_enh_req.png
> It would be great if the control from point no 1. could be added to point no
> 2. as well.
> Maciek
> -------------------------------------------- Managed by Request Tracker
