[GRASS5] rgb color support in ps.map ?
Sat Sep 3 19:35:58 EDT 2005
Hamish wrote:
> > PNG driver + pnmtops.
> > You'll get jagged lines, but that's a problem of the display
> > architecture which can't be fixed in an individual driver.
> Use pnmalias to fix that (sort of).
> pngtopnm infile.png | pnmalias | pnmtops > outfile.ps
I'm not sure how good an idea that is if you're planning on printing
the file. pnmalias will interpolate the colours; the interpolated
colours will then end up getting dithered for printing.
BTW, the PNG driver can write PPM files directly.
