[GRASS5] ps.map symbol size from DB column
Moritz Lennert mlennert at club.worldonline.be
Wed Sep 7 08:12:43 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hamish wrote:
> Great. It is now done and in CVS. Screenshot of PostScript file
> attached. Probably needs some testing.
> The new commands for the vpoints instruction are sizecol and scale.
Hamish, you're the man !
Just one small glitch: The resulting postscript file causes an error
("Error: /undefined in inf") when the sizecol contains nulls or
zeroes. In the code, you seem to have deliberately decided to allow
size=0. Does this mean that you were able to make it work with some
values = 0 ?
Also, what are the chances of having the print dialog in the GIS
Manager actually print d.vect.chart results via ps.map ? If I
understand correctly Michael is working on integrating d.vect.chart
as a button. Does that mean that it can be saved as part of a group
and then translated into a ps.map command ?
And (just to show how insatiable we are ;-): any chances of having
the full d.vect.chart implement in ps.map, i.e. allowing pie/bar
charts ? (I know I can create the charts outside as eps files and
depict them. I have been doing this with GRASS5 and R. But having it
all within GRASS would obviously make things easier.)
In any case, thanks for this great improvement !
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDHtk7rIrMbm76jD8RAgdmAJ0RPZm4s0ZLYo1fsZTSJAo5WhIeUgCeJy5O
CZ03BtKEmBKJYljV3d0Yt2I=
=xnce
-----END PGP SIGNATURE-----
