[GRASS5] ps.map symbol size from DB column
Moritz Lennert mlennert at club.worldonline.be
Fri Sep 9 04:41:48 EDT 2005
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Michael Barton wrote:
> Moritz and Hamish
> A major objective of the changes to the GIS Manager I've been making are to
> move all major display functions to GIS Manager layers with option panels.
> This makes entering options easier. It also allows for much easier creation
> of complex maps that can be modified and redisplayed. Importantly, it makes
> it possible to save all types of display features as a groups, including
> charts, thematic maps, grids, scales, frames, etc--as well as the normal
> raster and vector maps. without having to create commands and save them in a
> command layer.
> One problem that has come up in this is that the print function as currently
> implemented is limited to just doing basic raster and vector maps. I've put
> stubs to all the new layers, but it will require someone with a much more
> intimate knowledge of ps.map than I have to make it possible to directly
> print a complex map made in this way through the current print dialog
> (actually an interface to ps.map).
I have begun looking at the code, but haven't got very far in
understanding what needs to be done... I'll try some more when I
have time.
> While I hope this can happen, I've also created a couple of alternative
> solutions that might help in the meantime. One is a new script that will
> save display monitor output to a larger variety of graphic formats (the
> d.out.file script that I sent out for review a few days ago). Another is a
> simple print menu item that will send the display of the active  display
> monitor to the default printer via lpr.
Sounds good. Looking forward to testing it.
Moritz
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFDIUrMrIrMbm76jD8RAnLQAJ0YLRZezrOz8nWlBy5odLRnaVFMmwCfV/XZ
Zr88QjH1bGp3HxDv5XOA850=
=HZxq
-----END PGP SIGNATURE-----
