[GRASS5] [bug #3628] (grass) d.split: frames are NOT equal
Request Tracker grass-bugs at intevation.de
Mon Sep 12 09:08:06 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3628
Subject: d.split: frames are NOT equal
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs 23.08.05
d.split fails to divide the monitor into equal pieces.
As well vertically:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/dsplit/dsplit_vert.png
as horizontally:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/dsplit/dsplit_horiz.png
Screendumps where created in following steps:
d.resize width=800 height=600
g.region vect=frame res=1 -a
d.split 'cmd1=d.vect frame col=blue' 'cmd2=d.vect frame col=red' view=vert
d.split 'cmd1=d.vect frame col=blue' 'cmd2=d.vect frame col=red' view=horiz
My vector file 'frame' is here for testing:
http://www.biol.uni.wroc.pl/sieczka/udostepnione/dsplit/frame.tar.bz2
Maciek
-------------------------------------------- Managed by Request Tracker
