[GRASS5] [bug #3627] (grass) v.surf.rst: zcolumn has a default
Helena Mitasova hmitaso at unity.ncsu.edu
Mon Sep 12 09:43:28 EDT 2005
we put it there as a convenience because flt1 is the default column
name if you use
v.in.ascii to import the point data (at least it was the last time I
tried it).
This way I can import and interpolate the way I did it
in GRASS5 without checking the column names. I don't think this is a
bug, this is a feature.
Helena
On Sep 12, 2005, at 9:25 AM, Maciek Sieczka via RT wrote:
> Correction:
> This applies not only to GUI as I thought, but to v.surf.rst in
> general. Why
> do we have a default for zcolumn? Should there really be one?
> Maciek
> P.S.
> Changing the subject to "v.surf.rst: zcolumn has a default"
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
