[GRASS5] potential problems in d.vect.thematic when using a column of type real in postgresql
Thu Sep 15 20:30:51 EDT 2005
>  thus the only possible rewrite for 'a=b' would be:
> 'a/b < 1+1e-10 and b/a < 1+1e-10'
> which might run into division by zero errors and so on.
note for floating points, divide by zero just gives a value of "nan".
(not a number)
It is only with integers that it causes an error.
Hamish
