[GRASS5] [bug #3592] (grass) d.vect.thematic: cannot export legend with d.out.png
Fri Sep 16 09:40:58 EDT 2005
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3592
> Subject: d.vect.thematic: cannot export legend with d.out.png
> Platform: GNU/Linux/i386
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs20050830
> When creating a legend with d.vect.thematic, I cannot export this to a
> file with d.out.png. I have to use a screenshot to do so.
> It would be nice to be able to export the legend directly, ideally
> into a vector file, so that I could then modify it easily in a
> graphics program.
> Maybe there could be an option to export the legend with ps.map
> instead of displaying it with d.graph...
To survive d.redraw et al. d.graph input needs to be added to the
command history list via a temporary file. d.text does this already.
Then it will survive the trip through d.out.png.
Hamish
