[GRASS5] [bug #3653] (grass) changing regions within ps.map file
Request Tracker grass-bugs at intevation.de
Mon Sep 19 08:25:22 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3653
Subject: changing regions within ps.map file
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
Hello,
Would it be very difficult to implement the possibility to change regions in a single ps.map instruction file ? This would allow creating layouts with several maps, such as one of a large region and one of a zoom in one single run. Right now I have to create two ps.map instruction files, run them separately and change region in between, and then put them together in a drawing program.
Maybe a "simple"(?) ps.map element allowing to launch a system command could be a  solution ? But this obviously depends on how binding the order of commands in ps.map is. Otherwise, adding a "region" element to the individual map commands, such as:
vareas MyMap1
  region XXX
end
vareas MyMap
  region YYY
end
Moritz
-------------------------------------------- Managed by Request Tracker
