[GRASS5] [bug #4269] (grass) problems with r.contour
Request Tracker grass-bugs at intevation.de
Sat Apr 8 12:29:45 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4269
Subject: problems with r.contour
Platform: GNU/Linux/x86
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 6.1.cvs-2006.04.08
hello!
working with r.contour I experienced following things:
Mapset: grass_new (yes, I am trying out the new grass 6.1.cvs against the "old" 2006.02.25 ;-)
from shell:
g.region rast=elevation.dem at PERMANENT
g.region -p
r.contour input=elevation.dem at PERMANENT output=dem_isoipse_050 step=50 cut=0
I get the usual list of errors and then the vecotr map is created.
then
g.remove vect=dem_isoipse_050
g.region res=1
I get a program abnormal end (killed) at:
Reading data.
Percent complete: Killed
what happened? could it be possible to have some more explanatory output?
on the other hand using the r.contour GUI, I noticed that selecting the "suppress single crossing error messages" (this and only this) kills both the gui and the d.m (as well as gis.m).
ciao!
giorgio
-------------------------------------------- Managed by Request Tracker
