[GRASS5] v.digit segfault
Tue Apr 11 02:46:56 EDT 2006
> I know v.digit is broken by design, but it was workin.
I for one think it is a lot better than its reputation.
> Unfortunatly on my Gentoo box v.digit segfaults for both Grass 6.0.2
> and grass-6.1.cvs_src_snapshot_2006_04_08.
> Symptoms: after comand run it displays vectors but no toolbar etc. is
> shown. After that vect maps needs to be rebuilt with v.build.
(I haven't seen this, works fine for me in Debian/stable tcltk 8.4)
> I'm not an expert in gdb, but here's output:
> GRASS 6.1.cvs (Agnese):~ > gdb v.digit
> (gdb) run map=ttt
> Starting program: /usr/local/grass-6.1.cvs/bin/v.digit map=ttt
> [Thread debugging using libthread_db enabled]
> [New Thread -1219950928 (LWP 22555)]
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread -1219950928 (LWP 22555)]
> 0xb78b47c3 in strlen () from /lib/libc.so.6
> (gdb) bt
> #0  0xb78b47c3 in strlen () from /lib/libc.so.6
> #1  0xb79a9635 in Tcl_ExternalToUtfDString () from /usr/lib/libtcl.so
> #2  0xb7a687c0 in Tk_MainEx () from /usr/lib/libtk.so
> #3  0x080522d6 in main (argc=32, argv=0xbfab47d4) at main.c:199
> v.digit main.c 199 line is
>     /* Open toolbox */
>     Tk_Main(0, argv, Tcl_AppInit);
Unfortunetly gdb isn't much use for mixed C and Tcl programs v.digit and
NVIZ. It debugs the C to the line where it says "start main Tcl
application" ... Which just tells you the bug is somewhere after the Tcl
part begins..
for more clues try:
 g.gisenv set="DEBUG=5"
(0 is off, 5 is most verbose)
Hamish
