[GRASS5] Grass and GDAL-1.3.2b1
abhay menon abhay.menon at gmail.com
Thu Apr 27 00:50:12 EDT 2006
Hello Maciek and Lists.
sorry, that i forgot to put this on the list guess gmail seem make
commuincation one to one so i was only communicating with Jachym.
i was able to solve the problem  with grass61cvs and gdal-1.3.2b1
--quote--
final the problem solved..
1st compile and install gdal then created a softlink using ln -s command of
the libgdal.* to /usr/lib and then compile and install grass61 and thats it.
--unquote--
and
--quote--
each time when we compile gdal the --prefix is default set to /usr/local
hence all library compiled to gdal is set to /usr/local (and defualt library
to /usr/local/lib) where as while compilation of grass the library of gdal
was set to /usr/local/lib but when it was installed and executed the library
of gdal was been default searched in /usr/lib by grass. which is why the
softlink was need to be set for gdal /usr/lib from /usr/local/lib, so that
whenever the grass try to access gdal library in /usr/lib it is pointed to
/usr/local/lib.
--unquote--
Best Regrads
Abhay Menon
On 4/27/06, abhay menon <abhay.menon at gmail.com> wrote:
>  Hello Maciek,
> at first whereis gave this
> libgdal.so:/usr/local/lib/libgdal.so. 1 /usr/local/lib/libgdal.so
> but since i add a softlink to libgdal.* from /usr/local/lib to /usr/lib it
> give these too..
> libgdal.so: /usr/lib/libgdal.so.1 /usr/lib/libgdal.so
> Best Regrads
> Abhay Menon
>  On 4/25/06, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > On Tue, 25 Apr 2006 16:45:12 +0530
> > "abhay menon" <abhay.menon at gmail.com > wrote:
> > <snip>
> > > *Error in startup script: ps.map: error while loading shared
> > > libraries: libgdal.so.1: cannot open shared object file: No such file
> > What does $ whereis libgdal.so . say?
> > Maciek
> > W polskim Internecie s? setki milion?w stron. My przekazujemy Tobie
> > tylko najlepsze z nich!
> > http://katalog.panoramainternetu.pl/
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060427/f2d5afbb/attachment.html
