[GRASS5] error encountered in r.terraflow
abhay menon abhay.menon at gmail.com
Fri Apr 28 11:56:28 EDT 2006
Hello Shaun, Andrew and the list,
To Shaun:
yes I do have space...on the system there is about 44.5gb of free space
where as the *ESRI Ascii Raster grid* of size 960mb required 22.62gb as said
by the program.
>r.terraflow, it requires 80N where N is rows x columns of space to
>compute the output. This can be upwards of 40G for large rasters
Is that the Grass Ascii Raster Grid that you are talking about??.
To Andrew:
yes i do manually delete those files in /var/tmp each time when
r.terraflowfails.( already warned about the same each time terraflow
runs ).
Shaun's patch did successed in removing the problem with ami_stream.h for
the purpose of AMI_STREAM.
but i want to know from Shuan which version of the cvs build did you use, on
which your patch work and  where able to get the desired results on larger
files..
Best Regrads
Abhay Menon
On 4/28/06, Shaun Walbridge <walbridge at nceas.ucsb.edu> wrote:
> Do you have an large amount of disk space available on your /var
> partition? The error:
> file=/var/tmp/STREAM_UpisEN:cannot read!: Input/output error
> indicates you'd run out of space. As mentioned in the help for
> compute the output. This can be upwards of 40G for large rasters.
> cheers,
> Shaun
> abhay menon wrote:
> > hello all,
> > am still facing this problem.... even after updating the patch file..
> > r.terraflow December 2003
> > region size is 13593 x 15215
> > cell 960MBdata header compatible with region header
> > elevation stored as FLOAT (4B) WARNING: raster 960MBdata is of type
> > CELL_TYPE --you should use r.terraflow.short
> > STREAM temporary files in /var/tmp  (THESE INTERMEDIATE STREAMS WILL
> > NOT BE DELETED IN CASE OF ABNORMAL TERMINATION OF THE PROGRAM. TO SAVE
> > SPACE PLEASE DELETE THESE FILES MANUALLY!)
> > SFD (D8) flow direction
> > D8CUT=999999986991104.000000
> > memory size: 400.00M (419430400) bytes
> > Memory manager registering memory in MM_WARN_ON_MEMORY_EXCEEDED mode.
> > reading data from 960MBdata to stream /var/tmp/STREAM_kohqGU:
> > total elements=206817495, nodata elements=50042031
> > largest temporary files:
> >    FILL: 10.79G (11581779720) [206817495 elements, 56B each]
> >    FLOW: 11.68G (12542037120) [156775464 elements, 80B each]
> > Will need at least 23.36G (25084074240) space available in /var/tmp
> > COMPUTING FLOW DIRECTIONS
> > classifying nodata (inner & boundary)
> > finding nodata
> > relabeling nodata
> > MM warning: limit=419430400B. allocating 209608296B.  limit exceeded
> > by 23602B.
> > by 23633B.
> > merging relabeled grid
> > MM warning: limit=419430400B. allocating 209567256B.  limit exceeded
> > by 23558B.
> > by 23589B.
> > assigning preliminary directions
> > finding flat areas (plateaus and depressions)
> > plateau.cc:starting memscan
> > plateau.cc:memscan done
> > removing duplicate plateaus
> > MM warning: limit=419430400B. allocating 209567260B.  limit exceeded
> > by 23574B.
> > by 23636B.
> > relabeling plateaus
> > by 23570B.
> > by 23601B.
> > generating plateau statistics
> > MM warning: limit=419430400B. allocating 209403100B.  limit exceeded
> > by 23570B.
> > by 23601B.
> > assigning directions on plateaus
> > MM warning: limit=419430400B. allocating 209649312B.  limit exceeded
> > by 19306B.
> > by 19368B.
> > generating watersheds and watershed graph
> > creating windows
> > warning: using slower scan
> > generateWatersheds
> > MM warning: limit=419430400B. allocating 209628776B.  limit exceeded
> > by 10438B.
> > by 11182B.
> > r.terraflow: ./IOStream/include/ami_sort_impl.h:109: void
> > makeRun_Block(AMI_STREAM<T>*, T*, unsigned int, Compare*) [with T =
> > waterWindowType, Compare = priorityCmpWaterWindowType]: Assertion `err
> > == AMI_ERROR_NO_ERROR' failed.
> > Best Regrads
> > Abhay Menon
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060428/d78d5cfb/attachment.html
