[GRASS5] [bug #4366] (grass) core dump in r.to.vect
Request Tracker grass-bugs at intevation.de
Fri Apr 28 16:45:06 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4366
Subject: core dump in r.to.vect
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: GRASS 6.1.cvs checkout 4/27/06
There is a core dump in r.to.vect when run over DCELL rasters.  Segfault originates at this line:
#0  extract_areas () at areas.c:283
283           v_list[col]->node = h_ptr->node = 1;
I think that in r.to.vect there should be an error message on trying to run it on a raster other than of CELL type.
-------------------------------------------- Managed by Request Tracker
