[GRASS5] Re: auto-locate EPSG
Sat Apr 29 12:31:22 EDT 2006
Brad Douglas wrote:
> > 	AC_DEFUN(LOC_CHECK_SHARE_PATH,[
> > 	AC_MSG_CHECKING(for location of $2 data files)
> > 	case "$with_$1_share" in
> > 	y | ye | yes | n | no)
> > 		AC_MSG_ERROR([*** You must supply a directory to --with-$1-share.])
> > 	esac
> > 	AC_MSG_RESULT($with_$1_share)
> > 	if test -n "$with_$1_share" ; then
> > 	    if test -d "$with_$1_share"; then
> > 	        $3="$$3 -I$dir"
Oops; that should just be:
	        $3="$dir"
