[GRASS-dev] v.extract and sqlite-db
Markus Neteler neteler at itc.it
Wed Aug 2 08:32:52 EDT 2006
ok, I found a workaround.
On Wed, Aug 02, 2006 at 02:20:14PM +0200, Stephan Holl wrote:
> On Wed, 2 Aug 2006 14:02:50 +0200 Markus Neteler <neteler at itc.it> wrote:
> > On Wed, Aug 02, 2006 at 01:32:20PM +0200, Stephan Holl wrote:
I have changed the column type from 'numeric' to 'integer primary key'
using sqlitebrowser.
Find the new table here:
 http://mpa.itc.it/grasstutor/scripts/soils_legend.db
> > Does anyone have a suggestion how to resolve this problem?
> Probably a correct exit without segfault and an appropriate error
> meassage e.g.:  ERROR: Column 'id' is not integer
Mhh, the current message is:
Writing attributes ...
Layer 1
and it doesn't segfault (for me).
Anyway, for the example it should be solved.
Please try...
Markus
