[GRASS-dev] [bug #4951] (grass) proj folder and EPSG codes non-existant after 6.1 cygwin download
Maciek Sieczka via RT grass-bugs at intevation.de
Wed Aug 2 16:20:52 EDT 2006
> Installed Grass 6.1 using cygwin. Once installed, it opened up.
> I started to 'Create location from EPSG' only to find that folder proj does
> not exist. Searched in surrounding folders with no luck.
> tried installing proj package from cygwin again (twice) with no change in
> results
Where is you share/proj/epsg file located on the disk? And what path is there
in the "Path to EPSG-codes file" field? If these paths are different, press
the "Browse..." button, navigate to where the 'epsg' file shipped with your
proj instalation is located, then try again.
Does that work?
Maciek
-------------------------------------------- Managed by Request Tracker
