[GRASS-dev] Re: New installation for wxPython GUI
Yann Chemin ychemin at gmail.com
Tue Aug 8 23:14:37 EDT 2006
Works nicely on my system!
About "Zoom in" behaviour, i can replicate the reason why it displays
a blank screen.
1-type d.rast elevation.dem
2-click in any point of the elevation map
3-becomes blank screen
Now, here is the catch, if instead you try;
2-POINT and DRAG to create a (invisible on my computer) box in any
AREA of the elevation map
3-map zooms in properly
So it must be that "zom in" functionality should be allowed to zoom in
by factor X (2?) if only a click in a point is made, or something like
that...
y
On 09/08/06, Michael Barton <michael.barton at asu.edu> wrote:
> I figured out how to run gism.py from outside the directory where it lives.
> So now we can run it from a script on the GRASS command line without
> changing directories.
> There is a new distribution on my website (both tarzipped package and
> non-compressed files).
> For now, just drop the gmwxp folder into your $GISBASE/etc folder and the
> script "gm.wxp" into the $GISBASE/scripts folder.
> Then you can just type gm.wxp& from the GRASS command line to start the new
> GUI. It also reads the existing icon files, so you don't need the separate
> icon directory anymore.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
