[GRASS-dev] grass and python
Trevor Wiens twiens at interbaun.com
Mon Aug 14 00:33:03 EDT 2006
On Sun, 13 Aug 2006 05:59:20 +0100
Glynn Clements <glynn at gclements.plus.com> wrote:
> Trevor Wiens wrote:
> > > If anyone can find a real language which is "good enough" on all of
> > > Unix, Windows (Cygwin and native) and OSX, I'll quite happily rewrite
> > > all of GRASS' shell scripts.
> > Python is easy to install on Windows. So with an offer like that, I
> > can't help asking if any of the interactive Python shells are to your
> > knowledge good enough. Or perhaps what in you mind defines an
> > interactive shell environment that is good enough to replace bash?
> The main issue is the ability to have scripts which can be run as e.g.
> "d.save", and not having to use "d.save.py". This needs to work both
> from a shell and from system/exec/popen/spawn/etc functions provided
> by various languages.
A series so simple wrapper scripts might be needed to make sure that
issuing a map.draw command executes map.draw.py, but it seems desirable
to me to make sure that CLI use of commands would be the same no matter
what the shell of choice.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
