[GRASS-dev] [bug #5002] (grass) lib/gis/color_str.c does not compile
Request Tracker grass-bugs at intevation.de
Mon Aug 14 15:12:47 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5002
Subject: lib/gis/color_str.c does not compile
Platform: Solaris2.x/Sparc
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: cvs checkout 20060814
When compiling with Sun C 5.5 2003/03/12 the following error is reported from file color_str.c in lib/gis/:
"color_str.c", line 54: zero or negative subscript
"color_str.c", line 57: warning: syntax error:  empty initializer
"color_str.c", line 112: warning: statement not reached
cc: acomp failed for color_str.c
A workaround is to change row 46:
#define NUM_COLORS 1
and to uncomment line 56 to have one value in the table:
{"purple",  128,   0, 255}
It seems that a static construct without explicit initialization is not legal, at least in this compilers opinion.
Harri K.
-------------------------------------------- Managed by Request Tracker
